Looking at 18x9's help
Bravo1
Dallas
Hi everyone I new to your website,and just recently purchase a 2013 Ram 1500,crew cab,4x4.It has 20 inch rims and before I lay down some serious cash,I need some help,I was looking at a 18x9 wheel mounted on a Nitto Terra Grappler P275/65/18,should I go with this size or a LT275/70/18,it is a 10 ply tire,my bed payload is only 2600lbs.I am installing Superlifts 2" lift kit which includes a 1 inch lift spring for the rear as well,the front strut was going to be set at the 2.7 position.Should I select a 35x12:50x18 in a General AT2 or BFG ? Help.Thanks for the help guys,man I am burn-out on this already.
Burla
2010 Hemi Reg Cab 4x4
Can be stressful buying a new truck, hope you like it. I have had great luck with BFG but my tire guy says go with Toyo, for what it's worth. Sell those 20's on ebay, you can get 100 dollars a wheel at least if the tires are still good. I'm going down from the 20's as well when I get around to it, probably going with the Toyo AT. Your first tire is a 32, I like 33's or better for the 4x4, just my preference on that. Convert to inches.
Etroze86
Grand Forks ND
I would go with the most common size tire and if I remember correctly the 275/65/18 will have more options cause it came on ever ford pickup for the last two body styles. Or find a little wider and you start getting into commom standard and 10ply ratings. Actually never mind that do 17s or 20's you will for sure have a lot more options in tires than you will with the 18s.
