Looking to get 22" hellcat replica wheels, sizing help?
hdoggie24
Huntington Beach CA
Just like the title says, when looking at hellcat wheels made for the Ram, I see many different offsets and see 22x10 or 22x9.5. Anyone with the replica wheels that can help? I want them to fit just right, not sticking out too far but also don't want clearance issues from suspension components. I've been trying to research, seems like a lot are 25mm offset but is that the best size to get? I'm lowered about 3/5 on a Ram R/T. ANy help would be great.
Thanks,
KyleH12
Plano, TX
I've got the 22x10 with 25 offset. With 305/45/22s. I just got the belltech 2/4 kit put on last week and haven't had any issues.
Sent from my SM-G975U using Tapatalk
WhiteNBlackRam
Southern California
Do you have any rubbing issues? I have the same wheel setup. Except I got a quad cab and others have told me they rub with a 2/4 drop. So I’m not sure.
KyleH12
Plano, TX
Only been lowered a couple weeks, but haven't had any issues at all other than getting used to it riding different
CoreySinger
Canada
ecodiesel
This is a srt10 rep in 22x10. Same size same offset. 305/45/22. Belltech 2/4.
I have 10000kms on them. No rubbing of a upper a arm but its real close. A crazy hard corner may let the sidewalls flex to make contact. I doubt they would ever wear through tho.
They do rub the front swaybar at full lock but not an issue.
DoubleJ
Ansbach, Germany
I know a few with this setup. Works great and looks even better!
KyleH12
Plano, TX
Got a couple more pics the other day finally4ba6fb0caa8c040283b1d5627d11b76a.jpgdb8df1acd1252bb8132218496493d84c.jpg
Jtouch81
Cartersville,GA
That’s awesome! Yeah man it’s the one that Moes Performance sells without the shocks.. pulled this from Moes.
H
hdoggie24
Huntington Beach CA
Do you have the Hellcats with the 18 offset or 25 offset? I'm seeing if the 18 offset do not fit flush with the fenders and wondering if they stick out a little. The 25 offset should fit further inside the fenders than the 18 offset
KyleH12
Plano, TX
To be honest, I'm not 100% sure. I got them through a local wheel/tire shop. Factory Reproductions only offers the 25 offset (as far as I know) and I THINK that's where they ordered mine from. Mine sit almost exactly flush with the fenders. I'm running 305 wide tires which is just shy of a full 12 inches so they appear to stick out just a little.bff0f9fcb7090cec3eccf1fe7d7a89ec.jpg6f00af6ea6ddff01029199af5fa8e0be.jpg
H
hdoggie24
Huntington Beach CA
Thanks for those images. I'm thinking you have the 25 offset since youre pretty flush with those wide 305s. I searched more and saw someone with 18 offset with 305s and they seem to stick out more than you. BTW, do you know if you are rubbing on anything on full lock? either on the control arms or rubbing on any other suspension part?
KyleH12
Plano, TX
Not rubbing at all, but I do need to get my helper bags installed. I ride around with about 500lbs in the bed most of the time for work. I've been bottoming out on a few bumps.
H
hdoggie24
Huntington Beach CA
Awesome thanks for the info. Appreciate it.
