lower door seal where to buy
Huntingmark
Kansas City
Where do you recommend I buy the lower door seals for my 2004 Dodge Ram 1500? I cannot find seals for this range of model years.
all the mail order places
order through
Steele Rubber
They also go to all the big Auto Shows & Swap Meets
HemiLonestar
Navy Badge Coast Guard
MD
There was a TSB for these years back, it upgraded part numbers. Think I threw it away after I bought mine lol.
Edit: my OCD from the service for maintenance tracking has apparently quite spilled over into my personal life lol. @Huntingmark here ya go:
TSB 23-049-05
Drip Rail Door Seal Torn
Date: October 12, 2005
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-008-04, DATED
MARCH 2 2004, WHICH SHOULD BE REMOVED FROM YOUR FILES. REVISIONS
INCLUDE THE ADDITION OF 2005 MODEL YEAR AND REVISED PARTS.
Models: 2004 - 2005 (DR/DH) Ram Truck
Overview:
This bulletin involves replacing the secondary door seal with an improved seal.
Symptom/Condition:
The drip rail or secondary door seal may become torn from contact with the lower “A” pillar of
the front door.
Diagnosis:
Inspect the secondary door seal. If the seal is torn, perform the Repair Procedure.
Parts Required: Qty. Part No. Description
1 55277188AB Secondary Door Seal - Standard Cab -Right
1 55277189AB Secondary Door Seal - Standard Cab - Left
1 55277190AB Secondary Door Seal - Quad Cab - Right
1 55277191AB Secondary Door Seal - Quad Cab - Left
Repair Procedure:
1. Remove the secondary seal from the retainer (Fig. 1).
2. Install the new seal using the appropriate seal listed in the Parts Required section
above.
Policy: Reimbursable within the provisions of the warranty.
Time Allowance:
Labor Operation No: Description Amount
23-51-08-95 Install Secondary Seal, Both Doors 0.2 Hrs.
Failure Code:
ZZ Service Action
AVMotorcycles
