Lsd
jwilliams82
So I'm very excited to be the owner of a new 2012 1500 crew cab Laramie. After I got it home and got over the initial excitement I started looking over all the features to ensure I knew all I needed. And long story short I noticed a couple things missing that I sorta assumed would be on an almost 50k truck. Namely a trailer hitch and a LSD. The hitch was easy to fix obviously but the LSD I need help with. I found the unit below and want to make sure it's the right one. I also plan on installing it myself. Is that possible? I have never even seen the inside of a diff but it can't be that hard, or can it? Guidance please.
Chrysler Dodge Mopar 9.25 Trac Lok Positraction LSD 31 Spline Chrysler Dodge Mopar 9.25 Trac Lok Positraction LSD 31 Spline, Mopar 9.25 Positrac Differential [Mopar 9.25 Positrac Differential] - $289.95 : 3rd Strike Performance!!, Mopar, GM and Ford
bigbadram1500
Springfield, IL
Welcome to the forum. Not sure of an answer on this, but I'll bump it for others to chime in.
glass3222
Central PA
that will not work on your 2012. In 2011 they changed the rear diff and no longer use the 9.25. Your only option right now would be to try to get one through the dealer's parts department and have it installed.
J
jwilliams82
Thanks. The website says it goes up to 2011? That's not right? Any idea what size the new diff is?
glass3222
Central PA
They changed the diff part way through the 2011 production year. The new diff is similar in size, but made by a different manufacturer (ZF), and the LSD and ring and pinion are different and not interchangeable. No one makes an aftermarket LSD or ring and pinion for the new diff yet.
J
jwilliams82
well Chrysler (or Dodge or Ram or whoever) is doing a good job of shutting out the aftermarket on the 12's! no tuners, no diff's or gears, and apparently they changed just enough of the suspension to make the 2011 lift kits not work either. Oh well i'm sure the aftermarket will catch up eventually.
txbass06
NE Texas
5.9 Magnum
I wouldn't try the gear install yourself if you've never done it before. Setting the lash and proper installation of the pinion crush sleeve is a big part in the longevity of the gear set and is something that could be easily overlooked or performed incorrectly.
Gear upgrade is one of those things that most people suck up and pay to have installed by a pro
quietpeen
2021 TRX
Hellcat
i agree with txbass, the installing of lsd and or gears is not a straight forward easy swap for a novice.
on a side note, those of us with 2011's know your pain with the tuner :shooter:
Captain McGillycutty
Maumelle, Arkansas
2011 Power Wagon
Agreed with both statements said here! knock on wood all of my gear swaps have held up lol
joshhhh
