Armkb
- Jul 27, 2020
- 37
- 30
- Location
- Stormville New York
- 2016
- Hemi 5.7
Was wondering if anyone has installed a Magnefine filter in the cooler return line on a 8HP70 transmission.
When the Ford dealer put a new transmission in my old 2000 F-150 they put a Magnafine filter on it, and never told me. It was many many miles later that I was looking under the radiator and saw this funny-looking thing that had leaking transmission fluid on it, and I went on the internet to figure out what the heck it was. They should have told me they put it on and that it needs to be changed occasionally. That said, I think they do a great job, but because the Ram transmission is completely sealed, I see no reason to put one on.
In fact the reason I had to have a new transmission installed is because the dipstick came loose, and I didn't know it for a long time as fluid was leaking out, and dirt was getting in.
After the new transmission was on, about 70,000 miles later the dipstick came loose again. So frankly, I love the fact that the 8-speed is sealed with no dipstick!
After searching the internet, apparently there was a TSB to Ford dealers to put the Magnafine filter on when installing a new transmission, but they later rescinded that. It didn't come with it when I bought it new. I did order a new one and put it on, then drove the truck another 30,000 miles before engine was dying (300k miles), so I sold it as a fixer upper, and bought the Ram.
The 8 speed isn't sealed like i think you're thinking.It still has a vent to allow for fluid expansion/contraction.If it was completely sealed tight,it would blow seals.The vent is on the top of the tranny with a hose that leads up towards the back side of the engine. On a high humidity day it can suck in moisture laden air after the transmission has been warmed up,then the truck is parked and the transmission cools back down.It'd be a miniscule amount though.
I know many transmission shops install a magnefine filter after a rebuild or replacement to capture particles from the transmission cooler.
Worked well on my previous Tacoma. But that had rubber hose connections between the cooler and solid transmission lines. Hence it was an easy install. Not so sure how to go about installing on a Ram.
