NOcasio7
Hello all!
I am hoping that someone can point me in the right direction.
I have a 2015 1500 Express 5.7 8 speed Auto Crew Cab
I have searched google and the forums but I am getting some conflicting information.
Essentially I am looking for a schedule of when maintence should be performed.
I change my oil and oil filter on a set interval. I have 2 filtermags on the filter.
Also have an Oil Catch Can that gets dumped on set intervals.
I rotate my tires every 4500 to 5000. I have BFG KO2’s on there.
I have an AEM Dryflow drop in filter that I keep an eye on and clean when needed
What I am not seeing for my truck is
•Transmission fluid and filter flush (8 speed auto)
•Transfer case only states 120K but I have read conflicting numbers
•Spark Plugs @ 100k ( I am at 65k but do hear some pinging at WOT)
•Fuel Filter?
•Should coolant be earlier than 150k?
•When should rear diff be changed?
•Brake Fluid Change? (I changed the brakes once already but did not bleed after and have not opened the line to introduce any moisture)
•Any other recommended changes or preventive items I should keep an eye on or take care of?
•Fuel Filter?
