Many questions help if you can.
Ohio5pt7
Ohio
1. Are tow mirrors the same 13-18 I found a set but they say 13-17?
2. I plan to install the factory brake controller will alphaobd allow me to make it fully function without having the dealership flash it?
3. Mirrors from 1 have turn signals puddle lights heated etc. My stock mirrors are only heated will alphaobd allow me to turn those features on?
4. Will alphaobd work with a Samsung phone or do I have to buy a tablet?
Any help much appreciated thx.
McBroom
Denison Tx
Hemi 6.4L
The tow mirrors on the 18^ have the outside air temp (oat) in the mirror 17 down is in a different spot.
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
Ohio5pt7
Ohio5pt7
Ohio
Also I keep reading there should be 2 connectors for the brake controller and says it may not have them. What do these look like? I have a 18 express I would hope they are there but never know
78Staff
US Navy Veteran
NE Florida
The two connectors for the trailer brake controller will be under the dash just below the key/tipstart housing, usually in foam wrap. Check out this vid around 14:30...
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
1- dont know
2- yes
3- yes
4- yes...my samsung S8 works great
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
#1 Yes they will mount, plug in and function the same.
#3 Yes AlfaOBD will program this for you but you will need to change both front door modules.
Ohio5pt7
Ohio5pt7
Ohio
By changing modules are you talking about settings or actual hardware?
Sent from my SAMSUNG-SM-G891A using Tapatalk
circuitguy
Elk Grove, CA
5.7L HEMI
Actual door modules. You have one mounted in each front door above the door speaker.
Ohio5pt7
Ohio5pt7
Ohio
Any idea where to pick those up besides a dealer what would i need to search
circuitguy
Elk Grove, CA
5.7L HEMI
Here are the modules you will need to work the power folding mirrors.
DOOR CONTROL MODULE W FOLD LEFT 68225103AC
DOOR CONTROL MODULE W FOLD RIGHT 68225102AC
You will also need to change the drivers door window switch assembly to one that has the power folding button on it.
Choose two or four door truck.
MASTER POWER WINDOW SWITCH WITH FOLD TWO DOOR 68148895AA
MASTER POWER WINDOW SWITCH WITH FOLD FOUR DOOR 56046826AE
You will still need to use the AlfaOBD to turn on the power fold option once all is installed.
2names
EDM
How did you make out with this upgrade? I am looking to do the same on my '14 2500 Laramie and had a question about the modules...are they only specific to the power fold vs manual or do they also control the heated mirror etc?
Ohio5pt7
Ohio5pt7
Ohio
Worked out great just changed our the mirror truck already had all of the spots to plug everything in. Just had to flash it to activate. Everything works like it was a factory option.
