Maxtrac 2wd 4.5 lift
mattmid101
2010 2wd
5.7l
Can I use the maxtrac 4.5 lift kit with an already put on level kit? Or should I take that off during install?
Wandell
Cummins 6.7
Is the 4.5 inch lift just the spindle? If so you can. I know Maxtac sells a lift that combines a lift spindle with a coil spring spacer.
CRAM2014
You'll need a larger rear spacer though, or else you'll have the bulldog look with the front end higher than the rear. I believe performancelifts.com has the CST spindle set ups with 6in and 7in set ups. Just look at what they're using and go off that so you have a level lift.
mattmid101
mattmid101
2010 2wd
5.7l
Maxtrac has the 4.5 spindle with 1.5 rear spacer for 650$ or the 3 inch rear coils added on making it 900$.
Or the 7 inch for 1k. I'll look into the cat stuff
Sent from my SAMSUNG-SM-G900A using Tapatalk
sausec17
Banned
ATLANTA
Yes you can. That's what I did. I had a 2.5" coil spacer and added the 4.5" spindles. So you will be fine.
mattmid101
mattmid101
2010 2wd
5.7l
What did you do on the back?
LovedMy 2500
