Air Ride Conversion help
ajhudson15
Indiana
5.7l V8 Hemi
I have a 2014 Ram 1500 Laramie Longhorn that has the air ride suspension with height adjustment options inside the cab. I am looking to convert to normal shocks and struts with a lift/level kit. I was figuring with sales and what not i may be able to piece the kit together cheaper than the conversion kits. Are the conversion kits worth it or can i save myself some money? I would also like a parts list as it seems not all of the conversion kits include the same parts and im not knowledgeable enough to know what is needed and what isnt.
Dean2
Near Edmonton
This fellow is a site sponsor. He is an expert in what you want to do. Talk to him, get him to send you the parts, if you are close enough I would have them do the work too.
olyelr
Kewadin MI
Nahhh, if you want it lifted/leveled then just a normal lift kit. Otherwise you will likely be replacing the majority of the conversion kit anyway.
You will still need to change the programming to keep the lights off the dash.
Bob Templeman
