Maxtrac Suspension
When you do develop a set I want one!
Sounds like a plan! We appreciate the support!
Does this mean the 2/4 kit for the 19 is actually for a 4th gen with smaller coils in the rear and the front can’t be adjusted true
View media item 29067 So I was putting my MaxTrac 2/4 lowering kit in my 19 Ram Bighorn today and the bracket for the trac bar relocate is to small and don’t line up with the existing bolt holes
What’s the largest size tire that will fit on a 2” drop in the front?
Hey guys, just wanted to let everyone know that we just released our 2"/4" lowering kit for the 2019+ Ram 1500 2wd/4wd trucks. The kit utilizes 0"-3" adjustable front struts while the rear consists of 4" drop coils, track bar bracket, sway bar end links & rear shocks. The kit# is K332724 and is available through any Maxtrac Suspension retailer.
When you say 2019+, would that include the 2020 1500s'? I have a 2020 Big Horn Crew Cab Night Edition with a 6'4" bed and the 5.7 Hemi. I haven't been able to find a good 2020 kit anywhere.
Will putting this on my truck void my warrantee for any reason?
Also, can I put this in at home? I worked in auto body shops most of my life, as a painter, but I'm mechanically inclined.
just for example, I lifted my 2015 and my 2019 Classic with Maxtrac Suspension, I have never been questioned whatsoever on any warranty part. Id say go for it, enjoy your truck the way you want, now if you were doing engine or transmission, then Id understand, but many make lifting or lowering priority on their truck customization.When you say 2019+, would that include the 2020 1500s'? I have a 2020 Big Horn Crew Cab Night Edition with a 6'4" bed and the 5.7 Hemi. I haven't been able to find a good 2020 kit anywhere.
4th gen body style?Will this work on a 2019 regular cab Classic Ram?
Can this be used for a 3/5 drop? Maybe by taking a coil of the rear spring?
