McGaughy's 2/4 Economy drop
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
So who's running the McGaughy's 2/4 Economy drop? I've got one on the way and I'm curious to see the results on other trucks.
BMRbrnSNRbrd
BMRbrnSNRbrd
Norman, OK
I think he's a little lower...something like a 3/5.
Copperhead
Chesapeake, VA
I have the economy drop and the spindles along with a coil cut from the rear springs...... 4/5.... a little lower... :D
xpst500
CA
2011 4X4 QC SB BIG HORN
cant wait for the pics @copperhead
Copperhead
Chesapeake, VA
Stock height and then just the 2/4 with 22" Nightrunner SRT10 wheels
Snow
I like the way it looks I think I'm going with the 2" drop...
that is a beautiful truck.
Trupiano
Registered User
6.7L CTD
Copperhead,
Since you installed the McG 2/4 drop yourself, do you think it will work with a 4x4?
When I did the 2/4 drop on my 05 4x4, the only thing I had to alter, was to notch the spindle to fit the lower control arm. Lemme know what you think! I'd rather go with the McG spindle kit, then beltech's coil only drop.
BMRbrnSNRbrd
BMRbrnSNRbrd
Norman, OK
I think there's quite a bit of difference on how the 4wd and 2wd trucks are setup on the 4th gens. BTW, for anyone who cares, I did end up dropping the truck with the cheap McGaughy's 2/4 drop:
Before:
After:
BMRbrnSNRbrd
BMRbrnSNRbrd
Norman, OK
Depends on what you consider better. While I liked how it rode stock like a luxury car, I like more of a "sport" feel. It definitely stiffened it up a bit, but it's nothing near how bad my 2004 rode when it was dropped.
Trupiano
Registered User
6.7L CTD
Hey David, I was looking at the same drop kit, but they only currently have one for 2009. It worked for your 2010, do you think anything changed from 2009 to 2011? Wanna make sure it will work for mine.
OklaHemi
new age hemi
best bet would be to call them trup. there shouldnt be suspension changes that close in years
mitchman
SC
David, on a scale of 1-10, can you rate the original ride and the current ride? I love the smooth ride, and I don't want to (for lack of better term) **** it up.
A little stiff is ok, but if it rides like a 3500 then I don't like it.
BMRbrnSNRbrd
BMRbrnSNRbrd
Norman, OK
Original ride (considering it's a truck) was a 10 for me...now...7 on a bad day (or Oklahoma road.) Really, it's not that bad at all and I'm still on stock shocks and tires. I think a drop and then some aftermarket, and much better (which by comparison isn't hard with the GYs) tires will easily bring it back up to an 8-8.5.
southalum
