Morror turn signal running lights
Reel Hard
Hampton VA
Has anyone converted their turn signals in their mirrors to running lights and still have them flash when using turn signals? I have a 2017 Laramie without the tow mirrors.
Jimmy07
zacbar
Ontario
Joes1500
San Antonio tx
R
Reel Hard
Hampton VA
Next question would be does anyone have any pictures of the lights at night that has done this mod?
Jimmy07
Reactions: JB1
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I just finished installing the JHD Lighting kit on my 2014 1500. I have the courtesy lights on my truck, so I thought that I would use this circuit for the running light power. It works great and I did not have to run wires from the doors to the dash. I tapped the wire with the Yellow with Brown tracer color in each door. It works like the ones listed above except the turn signal does not turn off the running light.
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I did have to get one more of the wire tap things since the JHD Lighting kit comes with only one.
stimpy433
IOWA
brianw0048
EcoDiesel
could this be programmed with alpha obd?
1SloRam
Ms
Can’t find these on the DDP site. Keep getting an error 404. Anyone know if they’re still making these?
regal81455
Illinois
These are plug n play ones that I build for this vendor- https://dudesdieselperformance.com/...r-light-harness-13-18-ram-1500-2500-3500.html
Unlike the ones posted above, no pulling wire through the doors, and no splicing/cutting/tapping wires. They just plug online to the door modules.
I used this kit - it was an easy install. Did have an issue with one of the solenoids not working but the seller was prompt and sent out a replacement asap. Everything works great.
They have a new website. Here's the current link to the kit.
projectevaunit01
Buford, Georgia
I see it just uses relays to make it blink, I am assuming it blinks out of sync with the other turn signals? Like when the headlight and taillights turn signals are on these are off and vice versa. Or does it blink in sync with everything?
