motives 4.10 gears vs oem 4.10 gears
california
so my 2013 single cab has the 3.55 gears which suck at take off :nono:
and my next mod would be gears
i know oem is always best and more expensive
but is their a big difference between the motive 4.10 and the oem 4.10 gears
i know in price range is a huge difference what can you guys tell me about those motive 4.10 gears are they any good how do they work has anyone tried them did they fail etc......
http://www.moes-performance.com/Motive_4_10_Gears_for_9_25_Rear_p/c9.25-410.htm
http://www.moes-performance.com/OEM_4_10_Gears_9_25ZF_Rear_Axle_2011_up_Ram_1500_p/oem410.htm
huge price difference that makes me wonder if motives are any good??
DavidRam
SoCal - Redondo Beach
2012 RCSB
I did some readying before I did my gear swap two weeks ago, and couldn't find much info about the differences. But I figured using the oem gears that are in the R/T, should be my best bet. If there is a hair difference, I don't want to take that chance.
Besides if a warranty issue ever arose, I would like to be able to show that I have oem gears in my truck.
Will you be doing a LSD with your gear swap???
california
california
yes thats what i though to shoot for oem going to have to start saving some cash
ok about the lsd is that necessary to swap oh what is the difference between the one i have i currently have ANTI-SPIN DIFFERENTIAL REAL AXLE
DavidRam
2012 RCSB
Oops, I should have asked first. Anti-spin is LSD.
california
california
OH GREAT I DIDN'T KNOW THAT.
THAT IS ONE LESS THING I HAVE TO WORRY ABOUT AND WASTING ON :pepper:
SO BESIDES 4.10 GEARS WHAT EXACTLY ELSE DO I NEED TO MAKE THIS WORK?
DavidRam
2012 RCSB
Gear oil. New bearings x3. Mini install kit from Moes.
Here are good threads about that. They pretty much cover every possible thing:
http://www.ramforum.com/f44/4_10_w_lsd_vs_3_55_open_dif_-_gear_swap_review-47205/
http://www.ramforum.com/f44/4_10_gear_swap_express-28834/
Kelli25
Gear swaps freak me out. I would rather take the whole rear axle of an OEM setup. Ive been in the front seat of a truck with aftermarket gears when it locked up at 50mph. Not cool. Looked at the rear end afterwards and saw gears poking out of the actual casing. I know a bunch of people do this all the time, but thats their prerogative. :)
Good luck either way. I wish you success!!
california
california
Gears and LSD= WON'T NEED LSD AS I ALREADY HAVE
Diff Cover = DO I NEED DIFF COVER CAN I LEAVE MINE ON?
Install Kit = WHAT IF I JUST GO WITH MASTER INSTALL KIT INSTEAD OF THE MINI KIT
Bearings = THEY COME IN THE MASTER INSTALL KIT CORRECT?
Royal Purple Gear Oil = $60
DavidRam
2012 RCSB
Diff Cover = DO I NEED DIFF COVER CAN I LEAVE MINE ON? yes
Bearings = THEY COME IN THE MASTER INSTALL KIT CORRECT? yes
Royal Purple Gear Oil = $60 yes
california
california
california
california
No, definitely do not need a new cover. I just liked the Mag-Hytecs
ok cool good info
so did you feel a big difference jumping from a 3.55 to a 4.10???
hows that low end torque now?
professionalish
