Mounting rechargable flashlight inUpper glovebox
evansr235
I just completed wiring the reverse cam and lock pic chr550 in. I ran my wires inside the frame rail from the rear bumber to right at the fire wall. I am going to finish up inside the cab in the morning and would like to use the extra power leads from the lockpick to power my streamlight stinger. Rcghble flashlight. Streamlight recommends using 12v constant power. Was wondering if anyone had any input. I am also considering mounting the charger w extra battery in the upper glove box. Law enforcement uses thes light so I'm guessing it should hold up to high heat from interior.again any advice or concerns appreciated.
Thanks
Werkin onit
Mopar cai
Trinity diablo 1000
Lockpick chr550
Bar license plate cam
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
I like the idea of mounting the light in the upper glove box. You will not have any trouble with it being too hot. Those streamlights are tough and can take the heat. You should be fine.
res1551cue
Scott AFB, IL
I would like to see this done. Ive been wanting the Streamlight SL-20XP.
shawnb1043
Gonzales, LA
Sounds pretty sweet. Yea streamlights are pretty unkillable. Heat should be NP
Steve58
