Mud Flap extensions
GroguRV
Pepperell MA
Diesel HD
I bought the Weathertech flaps for my 2021 3500 dually. The work and fit great. Only issue I have is that they don't go close enough to the ground. I'm still getting rocks thrown up of the front tires and hitting the fender. Does anyone know of extensions for these mudflaps?
Thanks
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Not that I've seen. You'll likely need to make your own if you want to lengthen them. I was thinking about doing that with the Husky mud flaps on my truck. At least for the fronts.
retired
montana
Why not go with Mopar mud flaps they look great and fit great and hang pretty low.
G
GroguRV
Pepperell MA
Diesel HD
I looked at those and they don't look any lower than the Weathertech.
retired
montana
not sure but I thought the weathertechs were smaller maybe not. I know my lower panels are black and I am running 35's and I do not have a single rock chip on my paint anywhere. I am at almost 17000 miles and do a lot of gravel.FC00470E-2F79-4A26-834A-C5BCBD532509.jpeg
mikeru
Super Moderator
Eastern WA
2020 Limited
There are different versions of Mopar mud flaps. They also vary between 4th and 5th gens, and with/without fender flares. Can you provide details of exactly which ones you are referring to? You have a 2020 Power Wagon, and the OP has a 2021 HD. So it looks like yours may fit on his.
Dean2
Near Edmonton
Your issue may very well be your back tires throwing rocks forward. I have found this to be far more common. I actually mount flaps on the front of the rear wheel well to cut down on this.
Thread I posted about how to do it.
Moose2
Iowa
Duraflap and gator I think are into custom lengths for lifted trucks. I have the longer Duraflap’s on my truck. Non lifted this time around.
NRose
multiple
The DuraFlap are a drill-less installation full size mud flap. They do a great job. These are standard length and they have extra long if you are pulling a boat or have a level kit.
