multiple codes help
Eric C
NJ
2013 1500 tradesman
3.6L
Hello,
My 2013 Ram 1500 tradesman is giving me trouble.
This past summer it went into limp mode twice. I traced it to the oil pressure switch and replaced it. All seemed fine till the other day (9 Months later) it happened again and gave me six codes.
P0522 engine oil pressure switch
P0339 crankshaft position sensor A circuit intermittent
P0642 sensor reference voltage A circuit low
P2122
P018D
U1424
Anyone else have this issue? any help would be greatly appreciated.
clay282
Anon
3.6 Pentastar
It’s a 13… before the upgrades were made and weak point were upgraded. I would take it in. Oil, crankshaft, throttle position, voltage issue, fuel pressure… These codes are erratic and so different, I’d wonder if there’s a loose ground or the TIPM has gone bad, which is common. Your location says New Jersey. You just rolled through a rough winter with a lot of moisture and salt. If there was a way for moisture to get in and corrosion, you just went through it. https://youtu.be/ycGd8HCzFII?si=twHN2h-6AaP3VUjg
You might need to go to a garage that has a real Automotive Analyzer with Freeze Frame & all the other goodies.
A good shop will charge you for the basic testing, but it gets applied to the actual repair, unlike what dealerships do.
Dealerships often say that they can't duplicate the issue.
So they don't turn a wrench, because their machine does not tell them where to use it or which hand to put it in
