My 12v cummins build
1500ram12
1500ram12
5.9L Cummins
Definitely a good call on the rear main seal.
Might have missed it in the thread but what trans is in that?
Don't think I actually said. It's a torque flight A727 3 speed automatic transmission. From what I gather it's basically the same trans that came in a lot of Mopar muscle car's.
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
1500ram12
1500ram12
5.9L Cummins
Trans and t case back in. Little bit more work putting it back in than taking it out
2 coats of raptor epoxy primer
And 2 coats of rustoleum gloss black
1500ram12
1500ram12
5.9L Cummins
Got the parts truck in the garage. Time to steal some parts
1500ram12
1500ram12
5.9L Cummins
Finished with tearing down the parts truck, minus the bed.
1500ram12
1500ram12
5.9L Cummins
Got the hvac box installed along with the steering wheel and borgeson steering shaft
currently working on modifying the 92 gas core support for a larger aluminum rad designed for 91-93 trucks
1500ram12
1500ram12
5.9L Cummins
Got the driver's door mounted. Fitment so far not bad but not good. Bottom cab corner side needs to rotate down and quarter panel side needs to come up.
I did swap out the hinges from the parts truck since they were in better condition. So looks like they need some adjustments
New oil and fuel filter installed
92 gasser core support modified to fit a aluminum 91-93 ic rad. Just need to add some rubber grommets for the bottom mounting tabs and fab up upper mounts. And add provisions for the air to liquid trans cooler
1500ram12
1500ram12
5.9L Cummins
Got the driver's door adjusted, and passenger door mounted and just about adjusted right. Needs a little more tweaking. Tossed the passenger fender and core support on to check on fitment for the rad
1500ram12
1500ram12
5.9L Cummins
Not much done today. Got the wiring attached to the fire wall, parking brake assembly mounted back in the cab, master cylinder/brake booster mounted and fabbed up some upper rad supports.
1500ram12
1500ram12
5.9L Cummins
Threw the driver's fender on. Still need to adjust it. Both doors need to be adjusted back a hair.
1500ram12
1500ram12
5.9L Cummins
Not a ton done over the weekend. Added 4 gallons anti freeze (need about 2 more). Got the brakes bled. Will have to check them again once it's moving. Had to fix a couple of leaks (figured there'd be more [emoji1787]). Worked on getting grounds sorted out. And started patching the inner fenders
Treburkulosis
Your High End Detailer
Haslet, TX
@1500ram12 Good progress! How did you like the Eastwood stuff? I havent ever used it. I did some for 15 on my 67 Camaro. It did pretty good.
1500ram12
1500ram12
5.9L Cummins
The rust encapsulator is nice. Very durable once cured. Not a fan of the chassis paint so far.
1500ram12
1500ram12
5.9L Cummins
2 coats of raptor bed liner
Bluesea 150 safety hub came in the other day. Will be wiring this in soon. These are NOT easy to find, wow.
Treburkulosis
Haslet, TX
Hard to work with or just not what you expected?
1500ram12
1500ram12
5.9L Cummins
Easy to work with. Just not as durable as a would have thought. Almost seems like it could use a hardener or something.
brendo99
