Guyfromthenorth
Well, I learned a few things about our 2019 Ram Bighorn this morning. It was a brisk -55 when I woke up (that is not with windchill). I had her plugged into on the block heater from 0400hrs-0730hrs when I started her up.
-Engine\transmission\oil heated up to above 0 with the block heater, nice!
-Alternator belt and pulleys were not fans, lots of squealing.
-Trying to drive was rough, the differential lube was so thick that it wouldn't even budge without at least 1300rpm of power, and if I let off the gas it was like I had the brakes on and it would actually pull to a stop.
-The steering felt like no power steering was even on.
-Shocks were so stiff I felt like I would bend them.
-Lost 10psi of pressure in all 4 tires (readings once the engine was started...they returned to normal as I drove) and that is with Nitrogen in them not regular air.
-The tires deformed and froze in place, it was like driving on squares, bucking me in my seat, for the first 5miles at <5mph.
-The OAT gauge will not read passed -45 and just goes to -:- on the readouts, my hyundai read -55 when I started it up for my wife.
-The transfer case switch panel flickered like a strobe light (the backlight, not the selector lights) until the interior warmed up.
-The door latch failed and would close enough to shut off the light but refused to latch, I had to grab a can of lube from the shop, but did so with bare hands and actually burned my fingers on the can...I should know better.
Just another day. I do miss my winter tires, they grabbed amazing in temps like this and never deformed into blocks.
Attached screenshot from the weather network I took once I got to work (gotta love that windchill), and the OAT reading nothing on it's gauge as I mentioned. It's weird because my 2014\2012\2008 all read proper temps, I'm not sure if this is a problem with the 2019 or normal.
