My "check gas cap" saga - Fixed!
Justin33
I would say 99/100 times it's not the cap.
My cap did look terrible, the o-ring had some small cracking going on, don't know why, but wasn't the fix.
Yeah mine doesn’t look cracked or has to be the purge valve up top or the pump by the tank does P4057 matter in regards to pinpointing? I think that’s a large leak? I know I can take engine cover off and try and blow through that purge valve to know if it is bad.
EdGs
EdGs
FL
Can't really say. I had P0456 and P0457 as well as P0440 and P0441.
Just took a shot in the dark trying the ESIM first, and it turned out that was it.
I did not see any problems with the lines, I am fortunate to live in FL, and not have my undercarriage exposed to alot of crud and such.
Justin33
Squirrels galore atm. I don’t want to try gas cap cuz I know the seal looks good and took tin foil to the neck. I also cleared code with Alfa and it’s been 3 days.
Justin33
So it was the one by the heat shield? I mean I could go to dealer and have them smoke it but it’s obv the solenoid or esiim.
Justin33
Yep this makes me think it’s the solenoid which wouldn’t be hard to do do I just buy it from dealer and if I don’t need it return it.. watches osme YouTube and if you blow in that and can blow you know valve is bad.
Justin33
Yeah well I just had the shop smoke test and they kept losing internet when they were trying to get the values. Just paid a lot of money for no real answer other than I now know it’s the ESIM. No smoke leaks and even after thrm
Going down on their rate and not changing me for the lost internet was over 400 dollars.
EdGs
EdGs
FL
Ouch! Sorry. That sucks.
EdGs
EdGs
FL
Should have just bought an eSIM….least I know it’s not tank or anything else l….has to be ESIM
I believe that even if you reset the CEL, the codes are stored until you have 3 good engine cycles.
Justin33
Yes we will see I replaced the esim today with a duralast. Also siliconed tail light as they tried to tell me standing water is a inspection failure…I saw water droplets, not “standing water” as was stated.
UpstateNY2012
New York
Sorry to dig this thread up, but I'm having a similar issue—a gas cap (replaced with a new one) light and a P0456 code. I grabbed a Dorman ESIM replacement part and went to install it, but I have a quick question. I seated the new gasket where the old one was, but the new unit was a little tough to turn into place. I saw someone mentioned using the same unit and was curious if they had the same experience. I've cleared the code with my OBD reader and I'll be driving it around a few times to see if that was the issue.
EdGs
EdGs
FL
Seems like I remember mine was tight when I turned it to lock it in place. I think it rotates 90°.
UpstateNY2012
New York
Thats how mine went in. The old one was easy to remove and the new one was much tighter so I was worried I may have messed something up. Took it for a 40 mile ride and the code reappeared. Moving on to the next item.....
Appreciate the reply.
EdGs
EdGs
FL
Please keep us posted.
Justin33
Mine took a little for it to clear out, biggest issue was going in there blind behind that heat shield luckily the 4 inch lift gives me some more space.
LovedMy 2500
