My Ram Night on 37's
KiltedCelt01
PA
Your truck looks awesome, man. Very well done.
jdavila99999
This looks like a Zone upper control arm..
jdavila99999
Whoops I didn’t read far enough.
jdavila99999
Looks wow
Algunz
South Jersey
That truck looks so sick man. That is my goal right there with mine lol. I'm about to get a 6in rcx kit installed on mine with front bilsteins.
Just wondering, did you have to install new gears for the 37s?
JB1
JB1
Houston, Texas
Thanks, I have 3.92 gears and with the 8spd trans I haven't noticed any need for a lower ratio, it would be nice to have but not necessary.
One tip I can give you is select a 37" tire that weighs less than 80lbs and the lightest weight wheel you can afford (width adds weight). My 37's weigh just 4lbs more than a 35x12.50 nitto ridge grappler and 2lbs less than a 35x12.50 nitto trail grappler
Algunz
South Jersey
Thank you brother :favorites37: I will definitely put the weight into my search criteria, and I'm throwing them on my stock rims... saw another user on the forum did it and it looked clean as hell
Reactions: JB1
PDXRam
Portland, Oregon
What kind of numbers are you seeing for mpg? Truck looks great btw. I'm getting less than 15 mpg on a stock leveled truck, with the stock 20's...horrible so far. Probably just because it's learning my driving. My 6" lifted '16 1500 got around 15 mpg too, with 35" tires and 18" wheels! And some mods...
JB1
JB1
Houston, Texas
Is your mileage city, highway or combined?
My truck has always got terrible gas mileage, even stock it was only about 15mpg. For the record I drive fast and always speeding lol. I have a short commute w/o freeway driving, I only fill up twice a month so mpg isn’t important to me. I only drive about 5000 miles a year at the most.
If anyone here is concerned about mpg don’t go 37’s unless you drive a diesel.
Lifted2wd
I'm on 37's with hemi average about 14.6/15 on freeway.. 13.5/13.9 around town.
jhanes
nova scotia
hemi
nice!! funny that's the exact setup I ordered Monday !! just trying to decide on wheels/tires
will be 37"but I want AT'S and chrome wheels
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
If you can afford them I highly recommend toyo open country rt tires. Aggressive and have 10k miles on them and they still look greatSnapchat-1704338261.jpg
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
The Nitto Ridge Grappler is a very good tire as well ... that's the one I went with ... it's an AT/MT Hybrid ..
I was wanting a good tire in the rain and the last month here in Southern California was nothing but rain. These Nittos kicked ass in the rain, had awesome grip and felt no hydroplaning at all which is what I was concerned about ...
They are also not noisy at all but do sound nice going down the road from inside the cab ..
JB1
JB1
Houston, Texas
My Ram Night with BDS Lifted on 37's
Ground to Fender measurements:
Before: Front 36.75 and Rear 39.5 (2.75 rake)
After: Front and Rear both at 46.25
Parts List:
1. BDS Suspension Lift 6” front with optional 5” rear coils P/N 671H.
2. Zone Offroad Heavy Duty Upper Control Arm kit P/N D2301.
3. Bilstein 6112 60MM front struts with coils set @ 2.60” P/N 47-242548.
4. Bilstein 5100 46MM rear shocks P/N 33-185569 w/superlift 77-80038.
5. KMC XD-832 Wheels 20X9 -12mm offset 5x139.7 Hubcentric Satin Black
6. Yokohama Geolandar M/T G003 37X12.50R20 P/N 33337 (76.7 LBS).
Well it’s been 2 years since I had my 6" BDS lift installed and I am still very satisfied with it. I haven't had one single issue, no noises, no rust on the components, no alignment issues or anything, its been a great kit.
Over the 2 years I have added a few upgrades and in 03/2019 I lowered it some and changed the tire/wheel setup.
Changes highlighted in red below
Current: Front 43.75 and Rear 44.50 (0.75 rake)
Parts List:
1. BDS Suspension Lift 6” front with optional 3” rear coils P/N 671H (preload spacer never installed).
2. OEM Upper Control Arms.
3. Bilstein 6112 60MM front struts with coils set @ 0.00” P/N 47-242548.
4. Fox 2.0 Performance Rear Shocks P/N 98224758.
5. Fuel D670 Wheels 20X10 -18mm offset 5x139.7 Hubcentric Matte Black
6. Nitto Ridge Grappler Tires LT325/60R20 P/N 217440 (69.8 LBS).
7. Core4x4 Tier 3 Adjustable Rear Upper and Lower Control Arms and Panhard bar.
8. Hellwig Rear Swaybar P/N 7709.
wyobigchief
