Need advice for a 2010 4x4
rt2878
6.7 turbo diesel
Alright guys here it goes, i got a 2010 4.7 with a level kit. looking to go to a 4 or 6 inch lift. Prob i think i have is i got 20x10 with -24 off set with 305/55/20 so a 33" tire. how would that look will i need bigger tires?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
33s = too smal..
R
rt2878
6.7 turbo diesel
yea thats what i was thinking, what would the gap be if i went with a 6" and stayed with 33" for a bit
quietpeen
2021 TRX
Hellcat
welcome to RF. Post pics of your truck. its not exact but imagine 4 more inches of lift in the front of your truck and that would give you a rough estimate of the gap you would have with 33's and a 6" lift
Stangshcky12
Oshkosh, WI
5.9 Cummins
The stock tires on 20" wheels are about 34" theoretically I'm not sure what it actaully measures though
R
rt2878
6.7 turbo diesel
Thanks ill put up pics as soon as i can
garner
Harker Heights, TX
Definitely go 35s or bigger. Just look at how small 33s look on stock trucks with the 20" wheels
R
rt2878
6.7 turbo diesel
Thanks for the input, now what is a good lift to get. i already got the 35's coming, now got to sell the 33's
Mad Cow
Anchorage, AK
Cummins 6.7
I love my zone lift. I would recommend running a Procomp, BDS, or Zone lift. My experiences with Rough Country is not very good that is why I do not recommend them. One thing with the lift goes is looking at what the front and rear lift height will be. Example a 6/5 lift will raise the front 6" and the rear 5" causing the truck to sit with a rake where the back is higher than the front. If you were to get that you would want to get bilstein 5100's adjustable shocks to correct the rake. Or you could go a 6/3 lift and that would make the truck level and look good with 35" tires. Let me know if you have any questions and I will try my best to anwser them for you.
R
rt2878
6.7 turbo diesel
ahh ok thanks for that info!!!!! so a 6/5 with bilstein shocks i can raise the from up to level out the truck and 35"s wld also look good thanks. also sounds like i would gain a little bit of a higher lift.
