Need Assurance: Will a 2500 rear door fit my 1500?
AKreed22
AZ
4.7 v8
Alright guys just got back from overseas and the wifey backed the truck up with the door open and the passenger rear door is wrecked. I found a replacement one online thats the same stock black so it would be perfect but its off a 2007 2500, will it fit my 05 1500?? the site says it will but just want to get some outside advice!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
sure will. The doors are the same, but the inner panel may be different.
Are you sure the black is the same paint code? I didn't think PXR came out until 06? (I might have sniffed too much paint though........)
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
I know they moved things around on the front end, of the rams from o5 too 07. But yeah I think they will match right up. But the inside skins need to be swapped out. You can always try and cross reference additonal parts with a lmc catelog. btw. If the same number matches for both years , your good to go. Know what I mean?
A
AKreed22
AZ
4.7 v8
Appriciate the feed back ima look into those paint codes, as long as its close im probably gona have to go with it because paint shops have gotten rediculous with their prices. Thanks again for the info!
