Need help choosing transmission pan
novelmike
Central California
So....rather than pay someone to change my trans fluid, I'd rather do it myself and put some of the money that would be going to the mechanic into buying a new transmission pan. Specifically, a larger capacity aluminum one that will help keep the trans temp a little cooler. But which one do I need/want???
I have a 2012 Ram 1500. 6speed, 4x4. And I have no plans on changing the stock exhaust.
Thanks!
huntergreen
Marine Corps Navy Badge
Mag Hi-Tech.
Pull Ya
Cedar Creek, Tx
^^^^^^ this.
Jay
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
+1, and super easy to do yourself, +2 quart capacity, has cooling fins and can be found at moesperformance.com.
novelmike
novelmike
Central California
Looking on Moes Performance, They make several different pans for our trucks. Which one fits my truck? That's what I'm confused about.
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
fits mine, a 2010 4WD
Docpaulo
I have a 2500... but i did the mag hytec... only thing i would do different is use a new reusable gasket or a gasket maker.. the cardboard one it came with leaks slightly.. just a drop or two
huntergreen
Moe's had a great reputation on this forum. I would give him a call and let him tell you which one will fit your truck.
