Need Help Limp mode after changing transmission
adventurer
Amman-Jordan
2010 and 2006
Hemi 4X4 CC and Hemi 4x4 QC Sport
Hi all , i had issues with my 2010 hemi trany so i found 2012 4x4 truck with 21000 k miles on it that had an accident and owner selling it as parts so i bought the transmission , when first start and putting D after we fit the new trany truck entered limp mode (stuck on 4th) then code p0760(OD SOLENOID CIRCUT) we reset and cleared code started the truck again same thing limp mode again but with different codes p0871(OD PRESSURE SWITCH RATIONALITY) and p0882(TCM POWER INPUT LOW)
Any help please ?
TylerB
FL
2011 and newer use a different valvebody and solenoids. You need to swap them out.
adventurer
adventurer
Amman-Jordan
2010 and 2006
I ll swap them tomorrow though i think my original trany problem maybe were from valve body
charonblk07
Calgary, Ab
F1-A forged 349ci
Yeah, valve bodies are different between the years. If the valvebody was an issue on the old trans then you could pick up a performnace valve body from Matt, there's always that option.
adventurer
adventurer
Amman-Jordan
2010 and 2006
Thanks guys problem solved , i replaced the valve body and worked with no codes till now(couldn't wait till morning to swap )
