Need Help With Detailing
FTMike
Louisiana
The paint on my 06 ram is starting to fade. Anyone know what I can do to bring back the shine? Products? Would I have to bring it to a detailing shop for a wet sand? Any info is appreciated.
mperryz24
Alabama
Try a cleaner/wax first, before trying a more aggressive method like high speed buffing. Check into a DA polisher, it is hard to mess up the clear coat using that. Use Maguires and follow instructions. Your clear coat may be thinning out and would require repainting.
FTMike
FTMike
Louisiana
I'll give that a shot. Thanks for the info.
Pull Ya
Cedar Creek, Tx
IMHO on a truck that old I would go to a trusted detail shop and ask them to "measure" your clear coat and paint before you decide on what action to take. Depending on the thickness of the clear coat will determine what type of product(how abrasive) you can use. There is no doubt that you will need to use a buffer(maybe a Porter Cable 7424) to do the job. I always use the rule of thumb---"always start with the LEAST abrasive solution first". This will preserve what clear coat and paint you have left on the truck. DO NOT wet sand your truck before you know how thick the paint is!
Jay
Kinetic
To add what Pull Ya said, find out if the paint if single stage or two stage. Also, I wouldn't ever consider wet sanding OEM paint, especially older vehicles like yours. post up some pics with some good lighting so we can see what condition it's in.
To get it done correctly you'll definitely want to use a polisher, but what pad and polish depends on the condition and how much clear/paint you have left to work with.
Blackdodge2010
Alberta Canada
Power polish it with Meguiars Ultimate Compound. Then polish it with Mequairs Ultimate polish. Finish off with a coat of Mequairs Next gen 2.0 wax. It will look great.
FTMike
FTMike
Louisiana
Thanks for all the information. I'll try polishing it first to save money before bringing it to a detail shop. Unless I should bring it to a detailing shop first to see what they have to say about it.
Kinetic
You should have the paint measured to be on the safe side, much cheaper than having to repaint.
Pull Ya
Cedar Creek, Tx
FTMike
FTMike
Louisiana
