need help with Kenwood install
Rob McClure
Portland Oregon
5.7 hemi v8
Hi guys ,
I got a brand-new Kenwood DMX958XR head unit , iData Ads-Mic1, RR interface module, ACC-HU-RAM1 Harness, KIT-RAM1 bezel, how hard is it to do it myself? or should I just take it in? I'm in Portland Oregon, if anyone knows of a reputable place to take my truck in that won't cost a fortune to install this please let me know, any idea how much it would cost to have a local shop do the install ? thanks for the advice !
Ana1Ravager
AR
Hello,
It’s not hard like dealing with rusted parts/bolts hard, but it does take time to verify all the wiring is correct with all the different instructions.
Try to dry fit and write down all the connections before making them permanent.
For example, you can wire the Kenwood ground wire to the harness ground wire permanently. Then you find out that the module needs a ground wire too. So now you have to redo your kenwood to harness ground so you can add the module ground. Figuring out and double verifying the instructions and wiring makes this a lot easier.
On most vehicles, removing the radio kinda sucks because you can break all the different plastic pieces that are holding it in. On my 4th gen ram, it’s two screws on top and then you pull out the radio and bezel. I’m not sure if it gets easier than that. So that’s really good for you.
As far as price goes, you could call 4 and up star rated shops on Google/bing and ask them how much.
Good luck!
Lashlee
Knoxville, TN
To add to the very good advice offered above, it really depends on how comfortable you are with all of the modules and connections you will have. I've been an installer for over 30 years and have seen quite a few changes in that time. Some of the normal troubleshooting that I've been taught still works, but the modules can complicate things. I've done two recent installs with the MIC1 interface, one worked great and the other had echo and volume issues. To swap to the aftermarket microphone on that install required me to remove and reprogram the RR since I removed the MIC1 interface.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Hi guys ,
Nice setup.
It will be hard to find the actual information you are looking for. The physical installation is easy, and there are a ton of YouTube videos to guide you. The difficult part is setting up the iDataLink Maestro RR. I've been looking into doing the same on my 2015, and I'm hitting brick walls to find the actual information. It seems the info is readily available once you buy. I understand setting up the RR requires you to connect it to your computer and then program it using the iDataLink website for your vehicle and options. I'm also reading that the RR uses the OBD port to get its CAN bus data (why not from the radio connector) and also requires a 3-amp USB port to power it (again, why not from the radio plug).
What I am saying could be all out in left field because the actual information is not available until you buy. I just want to know what I am up against before I pay.
Does anyone who has installed a Kenwood and Maestro interface decloak the secrecy? Outside of programming the Maestro RR, is it all plug-and-play, or is discrete wiring (and how much of it) needed?
CanuckRam1313
Ontario Canada
2023 Warlock
Hi guys ,
I have the DMX957XR and it's a beautiful head unit with sooooo many levels of being able to dial in the tuning, x-over adjustments, etc.! I'm jealous and envious of ya Bud as the DMX958XR iteration has a few more bells and whistles over mine ;)
Not gonna BS - I did try myself first installing the head unit to attempt to save a bit, and as indicated by @BossHogg the physical installation isn't the issue whatsoever! and it wasn't for me overall... BUT!!!!!!!!!
What I learned visa-vie "if you're not experienced on how to program/tune/dial-in/and make it great overall" when it comes to having a high-end audio system and paying top-dollar for components to only have them not work properly AND not sound proper either... is, "Find a top-tier installer that has high-level experience with MOPAR Can-Bus systems as it can be tricky to dial things in properly after installations"!
I have a significant upgraded audio system with a total of 9 speakers and 2 subs with two Kenwood amps and a 5-farad db digital capacitor, and several additional grounds throughout, plus the H8 AGM Odyssey battery and sound mat everywhere throughout my truck, for my 2100W system that is all tied into my truck with the Maestro iDataLink module.
Updating the head unit and the iDataLink module, and then integrating it nicely into the MOPAR proprietary CanBus system with whatever audio upgrades you're doing and then also doing the proper audio sound tuning afterward is best left to professionals IMPO. If you're looking for that top quality sound and thump with zero distortion, that is ;)
I'm only guessing, but if you spent that kind of money on the head unit, you're likely also upgrading/adding more to your truck. What ya got going on?!
I will also add this though - ensure you have the audio shop add:
- High quality sound matt in all the doors at the very least!!!. And in the cab as well if you're really going for that next level as this is essential to the sound quality reproduction abilities of the upgraded speakers, and especially, to thwart the rattles heard inside and outside the truck.
- Several additional heavy-gauge thick copper grounds everywhere!!!!!
- If you're going with subs, especially, include an appropriately sized capacitor as this is essential to ensuring that your electrical/charging system can handle what you're throwing at it.... ask me how I know ;)
The item you can upgrade regardless is:
- The H8 Odyssey AGM battery as your electrical / charging system will thank you.
I believe that @CanuckRam1313 has used the iDataLink device in his last 2 trucks.
Maybe he can comment. :cool:
Thanks, Brother!!!! Much experience on this for sure, and I appreciate you reading me in to help our Fellow Member!!! :)
Lashlee
Knoxville, TN
Programming the RR is easy. There is no voodoo behind it. You tell the module what radio you have, the S/N of the radio, the steering wheel you have as well as the additional options you chose to purchase. You do have the option to modify some of the button functions (like holding down the volume down button can trigger a mute function) but it's not difficult. I don't know what @BossHogg is talking about for the USB...but it's much easier than the early days "integration". I recommend buying all of the accessories that will help you when wiring.
If I had one complaint of the RR: the wiring always look like a mess!! I've tried to pare down the harness to only what I need but it still looks like a mess based on you'll have connections on both sides of the box.
BossHogg
6.7L Cummins
I ended up buying the system from Crutchfield, Kenwood DAX1050XR, and all the iData installation stuff. It was a breeze to install; the only hang-up was the antenna adapter to use the factory GPS antenna. The recommended adapter was wrong; it had a GT5 connector, and the newer radios use a smaller FAKRA-to-GT21 antenna connector, which you can get from Amazon. Other than that, the factory MIC works, as do the steering wheel controls. Both the GPS and satellite factory antennas are used. All vehicle settings are available on the Kenwood screen, including the setting for my rear air suspension system. I guess the Maestro system is well thought out and works perfectly.
I don't know why they specified a 3-amp USB supply; it was in the documentation, but it wasn't needed. Same with the CAN bus; the Maestro radio cables included wiring to connect the CAN bus to the factory radio connector. And you are right about the wiring mess. Fortunately, the space behind the radio is ample to hold it all. I just shoved it all in the hole and crossed my fingers that nothing would rattle, and nothing did. I don't think there is a way to neaten that mess up. The only issue I had was the MIC connector to the radio; it kept unplugging when I pushed everything into the dash cavity. I finally rerouted it to give the cable some room, and that issue ended.
The package offer was a free SiriusXM module. Well, I got two modules (Crutchfield did not want it back). One was packaged with the Kenwood, and then Crutchfield threw in another module (I guess they missed the label on the Kenwood box that said a module was included). If anyone needs a SiriusXM SXV300 module, it is yours for the price of postage, or pickup if you're in SE Michigan.
Rob McClure
Rob McClure
Portland Oregon
5.7 hemi v8
thanks everyone for the input I greatly appreciate it !! I had some help and we got everything connected and running !
DITRIO
