GettinOld
Hi there. I'm new here and just bought my first Ram. 1500 Laramie low k's with the Alpine Sound system. So, I'm a car audio nut and actually used to install and repair car audio. I used to install professionally back in the day and still repair car audio amplifier in my spare time...
So, i will be replacing the 8.4 headunit with a Pioneer W4500NEX using the idatalink maestro RAM1 kit and MRR module. I will be using the chime speaker as well so could I bypass the Alpine amp and use my personal amps using the new headunit RCA's for signal? The idatalink retains most of the factory features.
So would this work or would I need another option to bypass the factory amplifier. Technically, i really just want to bypass the factory front door speakers, dash tweeters and sub. I can retain the factory amp to run the center dash speaker and rear door and headliner speakers. I plan on replacing the front doors and dash tweeters and run them off my personal amp. The Sub will be replaced with a custom box with 10" sub and would be running off another personal amp. I can just use the new HU front and sub RCAs and leave the maestro control the factory amp for the rear and center factory speakers.
Thoughts? Suggestions?
Thanks.
Thanks.
