Need help with Level/Lift for 2wd
cnjackson3
V8 4.7
Hey so I am just looking for some more clearance on my 2005 2wd 1500 and I dont want a crazy lift on it (since it isn't 4wd so I dont have a reason for it) but just something that I dont really need to worry about when I go hunting and to fill it out a bit more. I went to a shop out here and they had no idea on what I could do because they couldnt find any spacers for my truck or a lift kit for it.
SO i figured you guys would know best and have some suggestions for a solid susp lift that I could put on it!!
Colleen
hemipowerv8
Check out what CST has to offer...a 4" spindle up front and maybe do a small block in the back at 1.5" or something...nearly levels is and gives you room to run a 35" tire I would think....
TexasRammer
College Station, TX
This. Spindles are your best bet, someone also makes a 3" spindle that will conpletely level you out for a little cheaper
ram-head
Arkansas
This is for all the guys that have posted already, too...do the Bilstein 5100s work for his truck? I know they'd be more expensive probably than what has been suggested already and would still leave a slight rake, but I bet he'd notice big improvement in the ride quality, too.
TexasRammer
College Station, TX
You cant get adjustable shocks for 2wds, I dont think bilstein even makes any for them.... maybe they do, but theyre not adjustable
ram-head
Arkansas
Looks like you're right. I found a site that has them for 2wd Ford, but not Dodge.
Jus10case
