Need Help with longtube Headers
Raminator57
IL
I have a 19 5.7 hemi and installed ARH long tube Headers
1-7/8 https://americanracingheaders.com/c...truck-2019-long-system?variant=19842422112310
along with Diablo Tune 180 Thermostat and a catch can and K&N filter. I feels a lot sluggish now I regrett spending this money. It was pulling pretty hard for a truck with stock manifolds. So, From 1000-3000 RPM feels like a V6 and starts to pull a little more around 5000-6500. I put a stock muffler back on it to create more back pressure, but not much changed. Any advise besides the $9000K supercharger option?
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Yeah I wouldn’t be too happy after spending 2 grand on pipes either.
Even “high flow” cats will cause the secondary narrowband o2s to lean out the Long term fuel trims and you’ll eventually throw a code. Especially adding in a garbage canned tune that is bumping timing for more octane.
There are lot of great remote tuners for the 5.7 Hemi, just make sure they give you the TCM/PCM combo to make use of 100+ extra foot pounds of low end torque management lost from the factory.
CG2742
Mesa
Gotta get a custom tune with the setup. Also might invest in something that will allow more intake air flow. But a custom tune should solve all your woes.
Btp 2332
Curtisville PA
Before I clicked on your link I said I bet you put 1 7/8 headers on. I did the same thing and it killed the truck. Had a custom tune also and it didn’t matter they were just to big for my pretty much stock truck. Put the factory manifolds back on instantly loved it again. I was told 1 3/4 was biggest I wanted to go on just bolt on ram I should have listened. Think if I remember right it was almost 2 tenths slower at the track. This was also on a 5 speed auto maybe the 8 speeds make up for some of lost bottom end torque.
Raminator57
Raminator57
IL
Appreciate the kind response, can I get direction to where I can resolve this matter with a tune. is it worth to spend money on a
Victor EFI Gen III Chrysler HEMI Intake?
Raminator57
Raminator57
IL
Lol love it best response so far, I am so mad at myself a complete retard move and made a rich man richer
Btp 2332
Curtisville PA
I was so bummed and pissed I decided that I wanted to go back to a diesel. Put the stock manifolds back on and smiled again. Just being honest with you maybe think about taking them off, sell them, decide where to go. I had same headers, veraram intake, custom tune from one of the site supporters, and exhaust. It was a good running and towed my challenger great until I did the headers.
CG2742
Mesa
I put 1 7/8 on my 2013. Ran dual exhaust into a x crossover into two mufflers. With my other upgrades it was beyond amazing. I didn’t have forced induction. But I had complete opposite happen for me. Not sure why.
Raminator57
Raminator57
IL
good to hear, can you list your upgrades and exhaust brand please, I have a tradesman, it did not come with dual exhaust. I am not a big fan dual.
Raminator57
Raminator57
IL
I came from a diesel 2500 tuned to the gas side. Do not do it, It will cost you a fortune and a ***** to fix, every bolt on that beast needs a torch and hammer. 68RFE was replaced twice. one 4 wheel drive take off snapped the input shaft in half. EFI live and DEF delete with AFE intake, S&B intake and 35" tires was around $5K. the truck ran good but everything was a ***** to fix or replace. The two fuel filters at $150 a pop every 15000 miles, too much maintenance and costly.
Raminator57
Raminator57
IL
what your opinion on a SRT manifold https://www.ebay.com/itm/232482969148?epid=2294505602&hash=item362110963c:g:WlQAAOSwHm5ZtDYt
Btp 2332
Curtisville PA
I had diesels with billet transmissions etc etc etc used to race in 11.50 diesel class in a 98 12valve. I have had 6 Cummins and 3 hemi trucks I love them both differently. Raminator what’s your goal with the truck? Just a little added grunt or you plan on dabbling at the track a little?
CG2742
Mesa
I went dual with an x cross over due to I had no cats. And it sounded terrible at certain rpm. I put bolts exhaust mufflers and 5” tips. But I had Intake, throttle body, sos coils, tuner, pedal commander. After I installed the x crossover everything really opened up.
NDanecker
Earth
You need a custom tune, Canned tunes are absolute junk.
Agreed 100%. Find a local tuner that can take advantage of the extra flow you have, and lower temps. Just a simple tune without any of those physical upgrades would net you 30 or 40 hp, or more. The stock tune is very neutered.
Tach_tech
5.7L HEMI
Puting the muffler back on won’t do anything, the whole adage of needing enough back pressure is mostly a myth.
You need a tune, no other way around it. Changing more parts will just make it worse. Either put it back to stock, or get a tune. Even if you put smaller headers you’ll still need a tune to get the most out of it.
Doing any sort of mods on a modern engine requires a tune to get the most out of it, or even run properly.
Your PCM is calibrated to run properly with a certain amount of air, fuel and spark at a particular RPM and load. As soon as you change one of those the PCM starts seeing values it’s not used to It can have negative effects.
Canned tunes are also designed for a stock engine, even then they’re not that great.
If you’re not wanting to get a custom tune, just put it back to stock and sell the headers to try to recoup some money.
dtru1222
I put ARH 1 3/4 long tubes on my 5.7 challenger and it absolutely killed the performance, until i got a custom tune.. I already knew they needed to be tuned before installing but the 2 or so weeks between the install and the final custom tune felt like it was a 4 cyl.
After the tune it was a HUGE improvement over stock, 70k miles later and it still runs just as strong
OasisNinjaBat
