dss56
I was following a post on adding a shock sensor to the factory alarm which has none.
It Seems the wiring posted is not fully correct in the post.
So im trying to find the wire that will trigger the alarm as if the door is open. Suppose to be a negative trigger. Picture is of the plug on driver side left and the person said he found the violet wire to be the trigger wire.
I sat in truck doors closed and alarm on. I tried a couple of wires to ground but no alarm. If I open the door alarm will go off.
So in the picture can anyone tell which wire might be the negative trigger wire. Its very hard to check this out because you have to be at the connector on floor but doing so means the door is open so you can see what you are doing.
Other poster shows he is using the blue wire as the trigger wire, i tried and nothing.
I even sat in truck waited for lights to go out and added ground to the blue wire and no trigger to set the alarm off.
any help appreciated
Here is picture of connector
