jed2009
- Sep 3, 2016
- 6
- 2
- 2001
- 5.9L
Hey guys,
Yesterday I got some new headlights. They overall work great, but I think I'm having some wiring or fuse issues. I am terrible at electronics and wiring on vehicles, so bear with me. If you make suggestions, please explain things fully.
So as soon as I installed them, they worked great. The parking lights, highs and lows all worked. It came with a LED strip that I spliced into the parking light wire and that also works great. On the way home tonight, my driver side high beam quit working. Also, the lows were way too close to the ground and uneven, so I went to work getting those fixed when I got home.
I was able to straighten out the lows and make them even - great! However, I still couldn't get the driver side high to work. Then, after fiddling with the lights some more, my driver side low also doesn't work. So I am missing both lights on the driver side, but my parking light and LED strip work great.
I checked the fuse, and I am actually missing a fuse for the "left" headlight. I pulled a fuse from the Fog/DRL (I don't have fogs) and placed it in there - it did not do anything. I then took the "right" headlight fuse and placed it in to the "left" slot, and it made some weird stuff. It made the high beams turn on when I switch on "low beams" and vice versa. It also made the passenger high beam glow a dull amber instead of the bright color. I switched it back and the passenger side works as normal again.
Probably unrelated, but the heads on the cord w/ the blue snap attachment were loose when I checked. I got them re-seated and re-attached the plug and no changes were noted.
What would cause these lights from working 100% 10 hours ago, to the driver side completely fizzing out? The bulbs are in good shape, there's no way they could have blown on the first day. Would simply buying a fuse and adding it make the fix? I doubt it, as I tried adding that "fog light" fuse to the slot and nothing happened.
Please let me know if you can help!
Thanks!
Thanks!
