New HIDs and fogs! :D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
what?!?! a loud pop? what were they wired to? I've connected them backwards before, no issue - so...........weird! Let me know!
To3z
To3z
2012 Ram 1500 Lone Star 4x4
To be honest I can't tell you what exactly I wired them to since I had no idea what I was looking at besides what you said on the phone. I'll try and find some time this week to pop them back off and snap some pics of my attempt at wiring in the halos.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
This is what you tapped into right?
the lower 2 wires are ground (lowest) and parking (middle)
now, these aren't exact for your application (as mine were wired for dual color LEDs), but here's how I tapped into mine - I used positaps (not available at the local AutoZone), but any wire tap will do
To3z
To3z
Yeah that's the plug I tapped them into. The 2 open wires from the Halos that needed to be spliced were black and orange, I matched black to black and then the orange wire to the middle one. The weird thing was that the other headlight had a different color middle wire...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
hmm, thats just some weird **** there. When you get it popped back open, take some pics please!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Was the loud pop a fuse popping, that's usually the noise it makes. Did you check all of your fuses to see if you accident blew one while tapping wires?
To3z
To3z
So if by some chance I didn't screw up the wiring what would be the reason that the halos aren't turning on? (How can I tell if a fuse is blown?)
garner
Harker Heights, TX
Pull every one out by hand and check the metal to see if it's broken or go to autozone and get a fuse tester for like $5
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
there are no fuses on the halos.
They have a little cap inside of them that regulates power to them. Might be a problem there.
Take a 9V battery and try to power them from that. Let me kno if they come on them.
BlackedOutHemi
DFW, Texas
2012 & 2012
I'm not saying the halos have fuses. I'm saying whatever he's trying to pull power from to run the halos popped a fuse. Might wanna check them all. It's pretty obvious if the fuse is blown, so if you pull one and see it I think you'll recognize it. would be worth it if that's the case to not have to pull everything apart, and if not, then at least you ruled one thing oh.
To3z
To3z
I still haven't had a chance to try solving the Halo issue, but I did notice that the projectors are noticeably dimmer than my fogs.... And they also start extremely dim and then slowly progress to where they're at now. Could it that they're not getting enough power?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Got your pm, replied!
To3z
To3z
Finally got my Halos working!!! :D They look sick! Waiting for it to get dark so i can take some pics.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
sweeeeeeeeeeeeeeeeeeeeeeet
To3z
To3z
I had them wired right the whole time, but the T-Splice thing you told me to use never broke through the wire coating so it never made any contact haha
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
f'n t-splices.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I like positaps.........but they aren't at the local autozone!
I have a ****load of 'em here, just too big for what I normally use them for.
KAKA
