DuallyDean
I just mounted my second set (third, counting OEM) of tires on my 2018 Ram Rebel @ 130,4xx miles (it has the EVIC, if that matters). Prior to mounting the new tires, the TPMS system was functioning perfectly. Almost immediately after, I get a "Service TPMS System" message on the EVIC, and the TPMS screen shows with the Right Rear showing double dashes. Assuming I had a bad TPMS sensor (low/dead battery?) I figured I'd test the theory by swapping the RR tire to the RF. I expected the RR to now show a pressure, and the Right Front to be double dashes, but the dashes stayed at the RR. Additionally, the RF does not seem to update the pressure reading (it was reading 45 psi, and I inflated the tire up to 60 psi, but even after driving 50 miles to work the next morning it still reads 45 psi)
I assumed there was a "receiver" for each sensor near each tire, but internet investigation says there is only 1 module behind the left front wheel well splash guard, so where should I start trying to determine what component is at fault?
