"NEW" Towing Mirrors with Heat Function (Power)
Status
Not open for further replies.
Birddog
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
Can't tell if the have the puddle and turn signal lights?
I think you are asking if you have turn signal and puddle lights on your truck. If that's the case,
Mirror turn signal: turn on your 4 way flashers (hazard lights) and stand in front of your truck. If you can see the amber lights flashing on your mirrors than you have the turn signal option on your mirror.
Puddle lights: Look on the underside of your mirror. If there is a clear lens thats a sign. Unlock your truck while it's dark outside. If a white light illuminates the sides of your truck from under your mirror, that's the puddle light option.
When/if you decide to change your mirrors to tow mirrors, after taking your mirror off your truck there should be two (2) easy connect plugs. One of for turn signal and puddle light option and the other is for Heated and Power mirror option.
If you only have one plug, it is likely that you only have the heated and power mirror option.
I think that is correct... if I'm not, someone will chime in to let you know.
Status
