Newb with lot's of questions...
jcollins28
Rancho Cucamonga, CA
A few questions, just picked up my 16 Ram 1500 a few days ago. I'm more of a "car guy". I race karts so I had to buy a truck to haul my kart around in. That said I would like to improve the handling of this truck from the marshmallow soft ride to something a little more firm and sure footed through the corners. Looking at a slight drop and better dampeners and stiffer springs along with some solid away bars to shore everything up. Any suggestions?
razor1
St.Petersburg Fl
something in this direction?
audio1der
Airdrie, Alberta
It all depends what you're starting with. Do you have 17" wheels with chunky AT tires, or a Sport with 20" marshmallow P tires?
A 2"/4" drop with a stiffer rear sway bar go a long way on these rides. It also depends how much weight you tow, because you may need some of that suspension travel. I was only able to lower mine 2" in the rear in order to keep enough travel to pull our travel trailer.
jcollins28
jcollins28
Yes, great looking truck. What set up are you running?
I have the chrome 20's on it now. Was thinking about going with either the SRT 20's or 22's? Hearing different opinions on what kit to use for lowering. Seems like the BT kit has some issues with the rearend and the McGaughys has an issue pushing the front wheels out?
I'm not going to be towing a whole lot of weight well under 2k lbs. Can I even run the 22's on a 2/4 drop?
BHpgh
