No brake lights
larryt1939
deisel
2001-2500, Which fuse do I check? The peddle switch seems to have a selector on the back end, what is this? Any help, thank you.
L
larryt1939
deisel
All other lights work. Not brake light on cab.
txbass06
NE Texas
5.9 Magnum
The "selector" you see attached to the brake pedal is your stoplight switch. If all your running lights work on the back and it's just the brakes that don't, that's where I would start
Stangshcky12
Oshkosh, WI
5.9 Cummins
As dumb as this sounds I had both reverse bulbs go bad at the same time, I was thinking it was something more serious and felt like an idiot when I figured it out
Reticle918
