No forward/ parking gear but has reverse
Shortstaack
Guam
Have a 2002 ram with 46re transmission. I just rebuilt my transmission due to no reverse or forward gears. After installing and filled up with atf-4, I had reverse Nd forward gears and test drove it. After driveing for 5-10 min it would not shift into higher gears and then it lost allforward/parking gear but reverse works perfect. Was going up a slight incline and then it rpm jumped and now it feels like neutral in all gears but reverse. I droped the pan and found no metal and fluid still looks good. I am asking if yall got any insight. I replaced all seals/broken snap rings and the rear servo. Also changed governor pressure solinoid and speed.
