No Heat. Question about blend door actuators...
Jack W
2010 1500. No heat. Flushed system and just the heater core. It's pluged. Tried CLR soak, no change. I surrender. Filled system with correct Mopar anti-freeze. Going to have the dash pulled and a/c heater box removed. New Evap core, new heater core, and Geno's filter kit to be installed. I want to change the blend door actuators. All of them. Are they all the same? Aside from the one for manual temp control vs automatic temp control, I'm guessing those two are different?
Recommendations?
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Recommendations?
CLR is weak I would have used 5% vinegar off the shelf but then any rust through will create holes
I’ve done a search on youtube but only find stuff for Cherokees I’m not sure if they’re the same part number
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
For sturdy doors, you would not want the OEM part, because of cheap plastic gears
The OEM Actuators from Mopar are the best there is
That leaves Dorman doors, that you can get at many auto parts stores
If you plan to keep the truck for a long time, look at
Blend Doors USA
eterna14
