Your heater core may have a blockage and produce minimal heat...just from personal experience i was about to rip my dash out and replace my heater core, because a 30 minute drive to work when you have no heat and its 20 degrees just sucks! i heard a mopar rumor online and tried it. it said to swap your heater core hoses on the firewall and the reversed flow would break up or clear the blockage if you had one. In my case, it worked and my heat has never been as HOT as it is now. the extreme joy i felt from hot air flowing from my vents is unexplainable lol. good luck and hope this helps.
