No level, 33" tire question
RAMPART
Ok first and foremost let me apologize for being a newb and not being able to figure this out because it may be a simple problem but I tend to over analyze and over think things so before I move forward I needed some expert and or some veteran experienced opinions on what Im trying to do.
I drive a 2wd 2010 Ram 1500 TRX. Yeah... its not exactly off road material but that $1.12 Flex Fuel is really relieving some pressure off my wallet right now lol.
This truck belongs to forum administrator QUIETPEEN.
What I have in mind is very similar. But I don't know if it will work or what the repercussions may be if it does.
What Im looking to do is have the same -24 offset on a Toyo Open Country or similar tire but do it with out a level on the front and lower the back 2". I don't intend to off road and I don't tow or anticipate towing anything anytime in the near future. Im just looking for a low wide stand with an aggressive tread 33" tire and would like the wheels not to rub lol Im not sure if that is asking a lot but I need some help. :help:
N1ck
Regina Sk
We have extremely similar plans. I've got 33x12.50x20's on stock 20's but I plan on running 20x10 -24 with the GF rear end drop.
R
RAMPART
Well I noticed you are 4x4 and Im not sure if your stock front height is taller then mine or not could be I'll have to research that unless someone could confirm to make sure. With the current 33x12.50 you're running you have no rubbing issues? And I take it you don't have the front leveled considering your Sig says you have a rear drop
R
RAMPART
Can you post a pic of your truck I'd just like to get a visual for the height with the GF Drop
N1ck
Regina Sk
Right now I'm 100% stock height no rubbing. I will be installing my rear drop within the 3-4 weeks. I will post a picture tomorrow, it's dark out right now.
N1ck
Regina Sk
Here is what 33x12.50x20 on stock 4wd suspension looks like. I will hopefully have her lowered next month (rear only).
N1ck
Regina Sk
Damn one file max attachment rule :crazy:
N1ck
Regina Sk
One more.
