Noisy brakes?
Peterc
Cummins 6.7
I have a 2014 Ram Limited 2500 and periodically when I am driving around 30 kph approaching abend or a roundabout and touch the brake there is a vibration and or a clonking noise from the front of the truck. It sounds as if there is a loose wheel sometimes and I can feel a shudder through the brake pedal. I have had the steering,suspension,and brakes etc checked but everything seems to be in order. It appears to be mainly when I steer slightly to the right and then swing left while depressing the brake pedal. Its as if there is a loose caliper. It does not happen all the time and in fact I can cover quite a distance between occasions. the truck has only done 28000 kms. has anyone had a similar experience or can they help with this problem
