o2 sensor bank 1 sensor 1
Southern Vermnt
anybody have any tips or tricks for changing the o2 sensor bank 1 sensor 1?
also NTK $35 vs Bosch $60 - any real difference.
Thank you in advance for any help.
Steve
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Only use Mopar o2 sensors. I know close to 30-40 guys now who have tried using aftermarket sensors from general parts stores, and they continue to throw the same codes until they are replaced with OEM Mopar sensors.
U
Southern Vermnt
CEL is not on any more. I cleared the codes and after 35 miles checked and in Pending codes, I see P 0132 O2 Sensor Circuit High Voltage Bank 1 Sensor 1.
Should I be ordering a new O2 sensor or wait?
Could there be something else causing the error?
Thank you,
Steve
blackbeautyhemi
Lewistown, PA
Yea just do the mopar sensors and be done with it. I tried the defoulers and wool trick and it didn't do a thing, actually caused another code to come up, now granted I have high flow cats but it wasn't worth the hassle, just put new in and you should be set.
