PNUTLT1
This was used on my 2014 ram 1500 express to add OEM projector headlights.
I got the vin off a 2014 ram r/t and got the part number for the headlight harness.
Its pretty simple to install, just follow the route off the old harness and connect as you go.
Plugs the headlights, AC fan, wiper washer water line, wiper washer pump, ac line, air bag sensors, active grille shutter and fog lights.
Its used to add oem projector headlights on non projector trucks and keep it as OEM as possible.
I just made some changed in ALFAOBD to make the high beam shutters work, activate DRL on headlights and cancel PWM.
This goes for over $150 online.
Ships to you for $80 via USPS priority mail.
I called my parts supplier earlier and he said it should fit any 14-17 Ram 1500 with V8 and active shutters.
DM with any questions!
