OEM Projector headlights blink/flicker
Awastatyme
Southeast Texas
2015 Ram 1500 Crew Cab Laramie
On my 2015 1500 CC Laramie, I have notice a blink/flicker every now and then on my projector headlights. It's not a complete off/on, more like a supper quick dim and back. It's not all the time either, more like once every now and then. Cant seem to find a pattern, maybe when the ac compressor kicks on. Is that normal?
Enlight
V8
If you are currently keeping your climate control on auto mode, it is very possible that the AC compressor kicking on will cause a quick dim of the lights. It can be similar to leaving the headlights on when the engine is off, then starting the engine. Usually you will see the headlights flicker or dim during the starting process.
This results from electrical power fluctuations in the system. When your AC compressor kicks on, a relay is triggered which engages the magnetic clutch. This requires a surge of electricity which can be visually seen as a quick dimming of the headlights. Or sometimes you will get a quick dip in the engine RPM's as well if at at idle.
jzales
I noticed the same on my 15 black express with projectors , it's driving me nuts. My ac was not running when I noticed it.
Awastatyme
Awastatyme
Southeast Texas
I need to try and turn off ac and see if this still happens.
BigDawg148
Douglas, Georgia
2015 Laramie Crew Cab
I noticed the exact same thing. Thank goodness. I thought I was crazy.....:)
Kribs12
Me too
I have the same quick flicker problem...ac was on...wasn't on..heat on heat not on...its starting to be a pain in the ass....any help?? And has anybody has luck talking with dodge over this?
R.L.K.
Bristol , Tn.
Enlight may be on to something here ?
Check with your dealer , I read somewhere a TSB Was either out or coming out on this ...
bigolayne
Springfield, MA
Limeybastard let me know that the tsb came out on headlight flicker.
GreenClassic
Las Vegas, NV
2015 Big Horn CC
I don't have projectors (I have the quad headlights), but mine also does something like this. It's just like if I have the AC on and the compressor kicks in causing a slight and momentary dimming, but it happens even if all the climate control stuff is off. I don't notice it driving down the road, only when stopped behind a car, facing a building, etc.
iam_canadian22
northern ontario
My 16 quads do it too, never noticed it on my 13 projectors but they did make the canbus a bit more advanced for 15 and up so might have something to do with that
stbear007
2015 sport crew
My 2015 ram sport with projectors does this also since day one. Besides the fact they really suck on hwy especially in dark. Not very safe as I'm in hwy most times. Especially if it's wet roads or even a light rain. My older 2012 with quad headlights with Sylvania silverstars made a huge huge diff to see much wider out in deer season. I put the Sylvania zxe in these projectors and not a diff. I had dealership re-aim as they said they did but I still see zero change. Again also flicker constantly. I thought it might be off of fog lights with a weak thin bracket or such but without fogs on I would be screwed seeing somewhat of the road. There should be a recall or free replacement for this since I would think headlights do make for a safe driving environment????
KAKA
