Oh crap...
TheMaddog
DFW
My hids went out, any thought? Usually work, but for some reason they went out. Emailed JJ, to let him know. High beams work. Which is weird.
reddot
Wolf Point, MT
5.9 cummins
JJ is out of communication this weekend.
hmmm so both right and left high beams work but both low beams dont?
but for now I normal set of halogens will work till you get it figured out.
LB3711
Trumbull, CT
3.6L V6
check all the wiring and make sure the fuse is good. Are you using a relay kit or a drop in kit?
Sent from my Transformer TF101 using Tapatalk 2
TheMaddog
TheMaddog
DFW
what ever the digital one is, that jj uses. i'm out of town and don't have access to any new heads right now.
TheMaddog
TheMaddog
DFW
i think the wires might have gotten loose, switched or came off. i'm gonna check in the morning
LB3711
Trumbull, CT
3.6L V6
you have projectors or just OEM headlights with a drop in kit?
EJM05
Somers, CT
440 Big Block
check your fuse, grounds and corrosion if any.
TheMaddog
TheMaddog
DFW
I'm gonna do that in the morning. So I can see. Where can I get a new fuse? And are the universal?
05singlecabHEMI
Lilburn,GA
i believe if the high beams work the fuse should be fine.
at the parts that connect the wires together. Female and male peices. give the wire a small tug. mainly do the ones for the low beam resistors. I had a problem where mine would blink and or stay off. a wire just wasnt crimped good enough to the connector. if that is the case you can go to an auto shop and pick up a new connector. Or you can try and fix it.
I just bought a new connector.
TheMaddog
TheMaddog
DFW
Alright. I'll do that too.
05singlecabHEMI
Lilburn,GA
also one more thing. test the resistors.
take the relay harness out of the pins
with a multimeter check for OHMs on the resistors
find a good ground for your black wire for your multimeter.
you will be testing the fins that plug into the stock OEM headlight connector.
there are 3 fins. you will be testing the 2 outer ones.
If i remember correctly they should have about 7ohms.
TheMaddog
TheMaddog
DFW
I got the heads to work. One of my red wires and ground came loose. So I went in and fixed it. So I'm gonna try to get my truck inspected. Then worry about the rest lol
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
good to see its cared for.
TheMaddog
TheMaddog
DFW
son of a beetch, my highs aren't working, they were now they aren't, any new ideas?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
all the same stuff. check the grounds, check for a wire pulled from the resistors, etc.
TheMaddog
TheMaddog
DFW
resistors are good, i'm gonna look in a bit
frenzy_6900
