Oil Dipstick Tube Replacement
Robert H
Georgia
I have to change the oil dipstick tube on the 2005 Dodge Ram, 4.6L v8. I’ve searched this forum and the web for any videos and have come up empty. It appears to be pretty straight forward but looking for any video or instructions of things I need to be aware of to avoid screwing anything up.
Thanks,
Rob
HarryS
Air Force
Clovis NM
should be one nut or bolt, then pull it out. Lube the oring on the new one (if it has one) and reverse the removal process.
jws123
nj
You will need to pull your intake manifold its way easier if you do if its rust use some pb blaster possibly some heat.
Howcome your replacing it?
noraa73
