oil pan gasket problem
MoparSickness77
When I did my diffs and trans case I noticed my oil pan gasket is seeping a little bit but not leaking. It looked a little tricky to get out and put a new gasket on. Has anyone done this and know the best way? I would like to not have to take it somewhere. Thanks
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Where is it seeping at? You can remove the pan with lifting the front of the motor up but its very hard to do, easiest way is to pull the motor.
Fedzilla
