Oil Pan Removal 2015 Dodge Ram 6.4 Liter Hemi
PhilipFornaro
Morristown NJ
6.4 Liter Hemi
I am having a little trouble getting my oil pan out. I have removed all the pan bolts and have the pan loose. I cant slide the pan out. Does anyone have a tricks they can recommend? Am i missing something? Thank you in advance...
grizzstang
Calgary, Alberta Canada
The oil pump pickup is what is stopping you. I have not done an oil pan on a 6.4 Hemi but in most cases when you try and do them in the vehicle you have to loosen the motor mounts and raise the engine a little so you can clear the pickup. Or if you have a 4x4 you can lower the front axle. Either is time consuming.
I sure someone here that has done one can give you some pointers.
