oil pressure gauge
steevensi
5.2 L
Hi,
Can you tell me where should be pointing the needle on the oil pressure gauge? Mine is around the 3/4 (right side of the middle).
I can't find this info..
Cheers
dapepper9
Iowa/Nebraska Border
5.9L V8
Hi,
Cheers
70 psi-ish is perfectly fine depending on driving conditions. 30-40 or so is normal for cruising but under load most rise to 70ish
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Largely it depends on engine wear, weight of oil and engine temp. Anything over 30 but below about 80 is perfectly acceptable under most conditions. If you're using factory 5W30 then I wouldn't change anything.
