Oil Pressure gauge
pappy437
Ohio
2003 Ram 2500 quad cab,5.7 Hemi four wheel drive, 8 foot bed, Laramie, with 46000 miles. When you start it the oil pressure gauge does not move, turn it off and restart and the gauge works fine. Anyone know what it wrong?
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
Could be the oil pressure sensor/sending unit.Located right above the oil filter.It was the fix when I had this issue.Around 20 bucks and 5 min. to replace.Wow 46k.I thought my mileage was low(91k on 2004).Good luck and welcome to the forum.
P
pappy437
Ohio
Thanks for your reply. About all it does is pull a camper, stays in the barn from late Oct. till April or May with the cover on it.
jws123
nj
Change the oil sending sensor aswell as change the oil and Filter I have seen bad filters cause this issue also never use FRAM.
P
pappy437
Ohio
Probably 5 or 600 miles on oil change with Napa Gold filter. Going to have the battery checked and put in a new sensor. If that doesn't work I will try the filter. Thanks for the ideas.
jws123
nj
Did this issue start after the oil/filter change? IF so change that first.
P
pappy437
Ohio
Changed probably last of May or first of June took this long to get that many miles. Just started doing this Sunday but will keep it in mind as a possibility. I think anything on these things is possible.
